Leaking Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 09:48 PM   #1
Question
Leaking furnace
I've read in forums to fix a leaking (from bottom) furnace, "remove small panel around the copper pipe and check the evaporator coil for a clog." I think Iím trying to open the right panel. My furnace stands vertical, Iím reaching up to a copper wire and padded wire (I think also copper) probably eye level to 5'9". It has two panels that look like they should slide apart, but they don't. I've tried sliding, pulling, lifting and sliding. I'm not 100% sure I'm going in the right panel if I can't get it open.
If anyone has a clue what I'm talking about I'd appreciate u tellin me.
Thanks!
071175jp is offline   Reply With Quote
Old 09-02-2010, 09:57 PM   #2
fabrk8r
fabrk8r's Avatar
Do you have water leaking from your furnace when the AC is running?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-02-2010, 10:58 PM   #3
:) Thanks and Yes
actually, only when the AC's on.
That's information I probably should've included originally.
Old 09-03-2010, 05:54 AM   #4
http://www.diychatroom.com/attachmen...e-img_4441.jpg. see the white pipe that's the drain it needs to be cleaned out u can wet vac the end where it terminates or cut the pipe and install a coupling to repair the cut. More pics A/C not working, condensation on pipe
kennzz05 is offline   Reply With Quote
The Following User Says Thank You to kennzz05 For This Useful Post:
071175jp (09-03-2010)
Old 09-03-2010, 06:46 PM   #5
Are you kidding me? Links to pictures too!? You are soooo nice! I'm gonna do it now! Thanks!
Tags
furnace , furnace repair , leaking water heater
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 08:52 PM
Furnace leaking water Red Squirrel HVAC 5 09-22-2009 04:13 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
