Old 06-23-2009, 01:08 PM   #1
Default leaking freon - nitrogen ?
Hey I got a unit that I think is leaking freon. I thought i put 5.5 pounds in it last week. the tenant called 3 days later and said it was freezing up. I checked the filter, coils and everything inside and cleaned inside coils. when I put my guages on the low side it did appear to be low on freon. I am still not sure if I am reading the guages correctly. So I recovered all the freon. YUP 5.5 pounds! not one ounce short. But when I pulled a vacuum it would not hold. It would hold for 10 min or so and then drop a little. So to make a long story short I am thinking about using nitrogen, but I dont have a clue how to do this.
Any help ?
wetbar is offline   Reply With Quote
Old 06-23-2009, 01:44 PM   #2
sktn77a's Avatar
Call an HVAC service tech to help you out.
sktn77a is offline   Reply With Quote
Old 06-23-2009, 02:32 PM   #3
ok any other suggestions
Old 06-23-2009, 02:32 PM   #4
hvaclover's Avatar
what do you propose to do with the nitrogen pressure wise? Need to know so I can tell you which path of repair to take.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 06-24-2009, 11:51 AM   #5
Well I was going to start with a 100 and hope I could hear something. If not I will give it another 50 or so, or just see if it is holding. I have other stuff I could do while I wait an hour or so to see if it holds. If I do hear something, just hope I can get to it before I use 20 lbs of N1.
Old 06-24-2009, 11:56 AM   #6
Not sure you're going to hear a small leak. One option is to charge to 200-300 psi and go around with soap bubbles to find the leak. That will only work on fittings, but not the coil. The other is to add a 1/2 pound of charge, add the N1 to 200-300 psi and then use an electronic leak detector. If this is a small leak you may need to be pretty close with a detector. It seems leak detection is part science, art and luck.
dac122 is offline   Reply With Quote
Old 06-24-2009, 12:04 PM   #7
I have tried the soap and the leak detector with no luck. I was told (and hoping) I would be able to hear a leak.
Old 06-24-2009, 01:17 PM   #8
hvaclover's Avatar
300psig?? Thats a lot higher than some evap press burst test pressures.
Old 06-25-2009, 10:11 AM   #9
You don't need a constant head (tank valve open). Pressurize to whatever pressure and close off the tank.
A leak anywhere will show on your gauges.
BTW, it's N2
veesubotee is offline   Reply With Quote
Old 07-01-2009, 02:42 AM   #10
WOW! ok I went to 325 with out hearing anything. The pressure will hold for about an hour, and was holding when I left. I went around with soap with no luck. I was thinking I would go back in the morning to see if it was still holding. MY question is does freon leak faster then N2?
More On This Topic
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Leaks can occur from any part of the system. The compressor may be kicking on but it could be leaking. It's a major source for leaks as are the lines. The condenser is exposed to... Read More »
Gardening with Nitrogen
Gardening with Nitrogen by Expert Village
Hi, I'm Stan DeFreitas, Mr. Green Thumb for On Gardening. One of the most important elements of all plants is nitrogen. Nitrogen is always always the first number on the bag or on the bottle. It will usually be NPNK. The first number is Nitrogen. Why is... Read More »
Get a Walkthrough of the ammo guage in Halo 3 with expert tips and advice on video games in this free video clip. Read More »
In this segment we're going to talk about chemical grades or chemical compositions. Generally speaking, when you buy commercial fertilizers especially, and even organics. They tell you how much of the specific plant food types are in the fertilizer that... Read More »
Over here, we've got a downhill bike. It's got coil springs in the front--you can't see them, they're inside the fork, but there's a coil spring in there that gives this thing eight monster inches of travel. There's a coil spring here on the back. It's a... Read More »
Ridge Vent Leaking 35thLE Roofing 5 01-08-2009 01:33 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 01:08 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing 8 05-03-2008 01:00 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 10:53 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 03:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
