Leaking Evaporator Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 12:49 PM   #1
Unhappy
My AC unit isn't cooling properly. Had someone come out and tell me the evaporator coil has a leak and needs to be replaced. My question is whether I should simply replace the evaporator coil or replace the entire system. I have a 4 ton Trane system that is 11 years old. He didn't say there were currently any problems with the compressor/condensor. He did say that the new coil would have to be retrofitted to work with the Freon in my existing unit. Considering the age of my system, if my compressor goes out in the next couple of years and I have to get a new one, am I going to have to replace the coil again or have issues with the fact that at one point it was retrofitted to work with Freon? Any recommendations would be appreciated - thanks!
greeneyedgirl05 is offline   Reply With Quote
Old 06-24-2010, 04:45 PM   #2
At only 11 years old I'd replace the coil. It will still work when you change the system after being flushed out and the expansion valve replaced.
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 07:52 PM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
