Old 08-07-2012, 04:35 PM   #31
Leaking evap. pan!
Well looks like we aren't going to be able to afford none of the options.
Thinking about trying to blow out the a coil with compressed air and maybe it will quit "sucking the water over the pan"?
Also: there should be no issues with water in the winter while running heat pump am I correct? Just wont be efficient?
Mike
MikeVila is offline   Reply With Quote
Old 08-07-2012, 04:50 PM   #32
An old Tradesmen
Leaking evap. pan!
very little water in the winter from defrost occasionally.
Upstairs bathroom sink leaking through ceiling Cdessel Plumbing 7 11-17-2011 08:52 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
