Leaking Air From Lennox Handler/furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 12:36 PM   #1
Leaking air from lennox handler/furnace
After checking my ductwork for leaks this weekend, I found warm air blowing from the two openings around the two separate lines seen in the photo. One is about 1" or 1.5" in diameter with black wrap around it, and the other sits below the first by about a foot and is copper...much smaller in size.....what they are, i have no idea, but i can feel air blowing from the cut outs around them on the unit.....Can i patch these holes or are they supposed to be blowing air?
Leaking air from lennox handler/furnace-attic-001.jpg   Leaking air from lennox handler/furnace-attic-002.jpg
unclesam is offline   Reply With Quote
Old 02-22-2010, 01:08 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Those are your freon lines to the A/C. You can patch thrm. Go to HDepot and buy a roll of tinfoil type duct tape and use that. Regular stuff falls off after a year. Or seal them with silicone.
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 11:43 AM
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 03:48 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
