Leaking 90+ 398AAV - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 12:56 PM   #1
Leaking 90+ 398AAV
Condensate is dripping from the right lower corner of the metal box(secondary exchanger?) just above the plastic draft inducer fan assembly.
bruce granger is offline   Reply With Quote
Old 02-23-2012, 01:53 PM   #2
Could be a seal leak or dripping hose...did you try to locate the source?
hvac5646 is offline   Reply With Quote
Old 02-24-2012, 11:02 AM   #3
HVAC Tech/ Browns Fan
What kind of brand is it?
Tator1076 is offline   Reply With Quote
Old 02-24-2012, 05:52 PM   #4
It's a a Bryant 398AAV series
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
