Leak On Top Of Hydro Heater System - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 10:36 AM   #1
Rewards Points: 27
Leak on top of hydro heater system
Hi folks
I just bought a house and notice a leak coming from a piece on the top of my hydro heater system. Pictures attached. Any help on clarifying if this is something normal or needs to be repaired?
rogerusp is offline   Reply With Quote
Old 06-22-2013, 10:48 AM   #2
An old Tradesmen
Rewards Points: 6,476
Its an auto air vent. Easy to replace. Need to shut all teh water valves first though. And to belld off the pressure from the boiler before removing it.
Old 06-22-2013, 10:49 AM   #3
Rewards Points: 27
Thank you!
Old 06-22-2013, 10:53 AM   #4
An old Tradesmen
PS: Until you replace it(this summer yet). You can tighten the cap on it so it stops leaking water.
Old 06-22-2013, 11:30 AM   #5
Rewards Points: 27
Just called a local HVAC company and they charge 185 just to show up and check the problem. Does it sound about right?
Old 06-22-2013, 11:50 AM   #6
An old Tradesmen
Thats a little more then me. But every area and company is different.
I'd call another company or 2 to see what they charge.
Old 06-22-2013, 12:17 PM   #7
How big are the threads on that, 1/8"??
Since this is a DIY site...
http://www.amazon.com/Watts-Brass-Tu.../dp/B000MINF34
http://www.amazon.com/Rectorseal-257.../dp/B0009PU9CK
(but buy it from your friendly local hardware store, then it comes with free installation advice and you can swap it easily if the threaded fitting on the bottom isn't the same size as what you have)
taxmantoo is offline   Reply With Quote
Old 06-22-2013, 12:56 PM   #8
Rewards Points: 27
Much appreciated guys. Just worried the thing can splash boiling water in my face if i dont follow the right steps
Old 06-22-2013, 02:22 PM   #9
FClef's Avatar
Rewards Points: 160
OK, here are the steps to do this without having to drain the entire system. Please note that this method will result in the least possible water being drained. You may get a little water when you remove the air vent, but it is not going to be spraying all over the place, it will likely trickle out slowly. Oh, and it is best to put either towels or a large piece of cardboard on top of the unit so that what water does come out doesn't fry any controls. Take any precautions you feel are necessary, like gloves, safety glasses etc.
1. Get any hand tools you may need, like a pump pliers but more than likely you can do this all by hand.
2. Put pipe dope on the threads of the new air vent.
3. Shut off the automatic water feeder to the boiler.
4. Attach a garden hose to the boiler drain and run the other end to a drain.
5. Open the boiler drain and watch the pressure gauge on the boiler.
6. When the pressure reads ZERO PSI you can now remove the old air vent.
7. Quickly put the new air vent in place and take care not to cross thread as you tighten it.
8. Once the new air vent is tightened then you can close your boiler drain and turn your water feeder back on. And loosen the little cap on the air vent if it isn't already. If you think it is needed you can use the pump pliers to tighten the air vent but don't go overboard. normally hand tight and a quarter turn is more than enough.
FClef is offline   Reply With Quote
Old 06-22-2013, 02:52 PM   #10
Rewards Points: 27
Thank you fclef! Will give it a try
Old 06-22-2013, 03:19 PM   #11
Rewards Points: 27
The cap should be tight or loosen a bit?
Old 06-22-2013, 03:57 PM   #12
An old Tradesmen
Loose on a new one. When they wear out, or get dirt in them. they tend to either not let water or air out. Or they constantly leave water come out. And until its replaced, its best to tighten it to prevent water from constantly coming out.
Hot Water Heater Spigot Leak ellisje007 Plumbing 10 05-24-2016 04:10 PM
Radiant floor heating system has major leak, need to replace hoekzebs HVAC 3 03-29-2011 04:18 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 08:07 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 10:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 06:00 AM
