Leak Search With Dye - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 10:18 AM   #1
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
Leak search with Dye
Am looking for advice on whether the pros use dye and blacklight and which brand and how well does it work. Stuff is REAL expensive.
Old 05-09-2009, 12:37 PM   #2
HVAC / Plumbing
I have a kit I bought.. Comes with install tool ,dye, light, glasses for 92.99. If you have a leak on an A coil on the back side you mast likely have to pull the coil to locate it. There is also another kit that is offered with out glasses & light for 55.00
kenmac is offline   Reply With Quote
Old 05-09-2009, 01:00 PM   #3
Hvac Pro
yuri's Avatar
Can you find leaks outside on a condensor coil in the daylight or do you have to cover it with a tarp? Does the dye show up quickly ie: 1/2 hr or do you have to come back the next day. (I know depends on size of leak).
Old 05-09-2009, 02:18 PM   #4
An old Tradesmen
Rewards Points: 7,404
Not always easy ougtside to see it.
Covering with a tarp helps.
Had more then one, that I couldn't find with the dye.
Electronic leak detector found it instead.
Repaired a coupke leaks, on systems that I added dye too. When I took the copper apart, I couldn't see any traces of the dye inside the copper.
It needs to circuate with the oil. If there isn't much oil suspended with the gas, the dye doesn't work.
Old 05-09-2009, 03:33 PM   #5
HVAC / Plumbing
Leaks are just a pain in the A to find..
Old 05-09-2009, 10:38 PM   #6
Yeh dye can take a day or two, sometimes almost right away.
texas115115 is offline   Reply With Quote
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 08:46 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 08:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
