Leak In Gas Fitting At Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 05:34 PM   #1
leak in gas fitting at furnace
this union in the gas line just as entering the furnace has a minor leak that , at times, can hardly be detected.
Can i tighten this type of fitting , or should it be replaced?
thx
velotech is offline   Reply With Quote
Old 05-20-2013, 05:43 PM   #2
Rewards Points: 12,858
What kind of pipe is that?
The whole thing was suppost to be black iron.
Why is there even a union there?
Old 05-20-2013, 06:06 PM   #3
how
Rewards Points: 1,070
It's all supposed to be Black iron like your union fitting as galv pipe supposedly can internally slough off debris that can damage the gas valve.
In my area there is no problem with that union fitting location provided that there is adequate room to work your wrenchs.
Soap the fittings and if you detect any bubbles, use two wrenches to tighten it up while not putting the downstream fittings under too much torque. Usually only cross threading will require the replacing of the union.
how is offline   Reply With Quote
Old 05-20-2013, 06:07 PM   #4
Rewards Points: 1,214
I would try tightening it one time if that don't work replace it with another one.
@ Joe, usually there is a union right before the pipe goes into the casing on the heater in case the gas valve needs to be replaced you can remove it without much trouble.
LEAK CHECK, LEAK CHECK, LEAK CHECK.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 05-20-2013, 06:16 PM   #5
Were required to use a SS flex line, no unions.
Old 05-20-2013, 06:17 PM   #6
biggles's Avatar
shut the gas going into the furnace and brake that union apart.check both sides of that unions seats if its leaking out the threads..reinstall it hand tight and double wrench to tighten it ..put a rag under it spray it with a dishwashing soap mix
Old 05-20-2013, 06:28 PM   #7
Rewards Points: 614
tighten the thing.. .. if it stops leaking go fishing or golfing.....
carmon is offline   Reply With Quote
Old 05-20-2013, 08:27 PM   #8
FClef's Avatar
Rewards Points: 160
I have found leaks like this before. I have used a TINY AMOUNT of pipe dope on the threads of the union simply for lubrication purposes so it pulls tight. If it is as tight as you can get it and still leaks, then it's time for a new fitting.
And like everyone has told you.... LEAK CHECK after tightening or replacing!! You really shouldn't use dishwashing soap, but if you rinse the fittings afterwards you should be fine. Your local hardware store should have leak detector solution. It is not that expensive.
FClef is offline   Reply With Quote
Old 05-20-2013, 09:19 PM   #9
Thank you all....but its neither fishing nor golfing....its in the user name.
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Furnace is in attic, I want to move it because of efficiency issues... SimonSezz HVAC 1 01-22-2011 07:23 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
