Is It Leak From The Basement Or From The Heater? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 07:48 PM   #1
Question
water leak under my Ruud Furnace
Hello
i have a water leak under my Ruud Furnace , it is brand new Furnace and it has been installed in the summer so the leak starts after i start using it in winter.i will attach some pictures..
Is it leak from the basement or from The Heater?-furnace-20002.jpg   Is it leak from the basement or from The Heater?-furnace-20007.jpg   Is it leak from the basement or from The Heater?-furnace-20001.jpg
samerhajjaj is offline   Reply With Quote
Old 11-21-2010, 07:53 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Remove the front upper and lower doors on the furnace and take a closer look...
If it was just installed call the installer..too
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-21-2010, 08:04 PM   #3
thanks, The installer came to my house and did install the Left white drainage that is close to the door but the leak did not stop and had to come again to fix then the leak comes from different location after the second visit.
Old 11-23-2010, 08:43 PM   #4
Question
i have a leak in my heater unit (it is brand new unit) i dont really know if the leak from the unit or the basement ?
Old 11-23-2010, 08:47 PM   #5
Try posting this in the hvac area. Those guys probably could help you more
warnerww is offline   Reply With Quote
Old 11-23-2010, 08:50 PM   #6
Question
i have a leak in the basement i would to know if the leak from my new heater unit or from the outside to the wall to inside basemtn
Old 11-23-2010, 08:57 PM   #7
Rewards Points: 560
So, Did YOU open the panels to take a look?
Did You call the installer back out to check?
Old 11-23-2010, 09:01 PM   #8
Hi,The installer is not answering my calls?, i did not open the panel
the installer came twice to my house to fix it and the send me a text after leaving the house saying something about the rain!! , but before i start using the heater i had no problems at all,i start getting the leak right after i start using the heater
Old 11-23-2010, 09:06 PM   #9
Rewards Points: 560
If you are not comfortable checking things out then call the company and ask for the owner.
Explain your concern and ask for a different tech or ask the owner to come and take a look.
Old 11-23-2010, 10:13 PM   #10
Have him put those high voltage wires in conduit like it's supposed to be while he's there. Can't believe any inspector would let that pass.
Help With Mysterious Basement Leak makaveli03 Building & Construction 8 07-25-2010 11:07 AM
Basement Floor Leak Celtic DIY Plumbing 5 08-04-2009 10:32 PM
Basement Leak twaters12 General DIY Discussions 7 11-01-2007 10:13 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
