Lazy Heat Pump Fan. Urgent Please Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2010, 11:33 PM   #1
Lazy Heat pump fan. Urgent Please help!
Hi,
I have an Armstrong Concept 1000 (SHP10E36A-3) outdoor unit. I noticed the heat pump putting out cold air recently. Outside temps in Northern VA are in the low 20s. I went out and noticed the fan was not spinning though i could hear a humming sound from the compressor. I just nudged the fan a little and the fan started spinning in the next cycle.
This morning i waited for the heat pump to kick in and I noticed the fan turned less than a quarter of a circle and stopped. there was no visible frost on the grill. I gave it a little nudge and it started spinning. I checked the cap and found it about 4.72uF for the fan. i also put some WD-40 to ease up the bearing.
Update:
I noticed some frost on the grill and again the fan was not turning. I presume it was a defrost cycle. I went out again after a few minutes and saw the fan spinning very slowly about 1/2 revolution per sec. I gave the fan a nudge and it started spinning normally
Do i have a bad motor or is it something else? Will running the heat pump cause further damage?
Please help Thanks a advance.
toxicprison is offline   Reply With Quote
Old 12-30-2010, 04:06 AM   #2
An old Tradesmen
Rewards Points: 8,154
Probably the motor is going out.
The Following User Says Thank You to beenthere For This Useful Post:
toxicprison (12-30-2010)
Old 12-30-2010, 08:54 AM   #3
Thanks beenthere
Old 12-30-2010, 08:56 AM   #4
i already ordered a new motor and cap. Is there anything else to diagnose before i replace them?
I cudnt find a manual for the heat pump. Does any one have a copy?
Old 12-30-2010, 06:12 PM   #5
An old Tradesmen
Might want to look at the contactor and see if its pitted. And also make sure the coil is clean. Other then that, not much else to check out, without the fan working.
Old 01-02-2011, 10:40 AM   #6
I installed the new motor and cap.Everything running like a champ. I will be keeping an eye on the pump for a few days to ensure everythings running fine. Thanks for helping.
Old 06-04-2014, 04:35 PM   #7
I realize this is an old post but believe i have a similar issue. Where did you get the parts plz.
Bigcahuna is offline   Reply With Quote
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
