Lay Down An Air Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2014, 07:52 AM   #1
Lay down an air furnace?
Can you lay a high boy air furnace on its side without hurting anything? I have to help a friend get a furnace and wondered if we should leave it standing up or can it be laid on its side in the bed of the truck without any damage. It is a direct drive if that matters. Thanks.
Plumbvoltage is online now   Reply With Quote
Old 06-29-2014, 08:02 AM   #2
An old Tradesmen
Rewards Points: 6,142
For transportation, you can lay it down on its back. Laying it on its side, can cause the blower wheel to slide on the shaft when you hit bumps in the road.
Old 06-29-2014, 08:54 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
It is better upright. On its back and the wheel in the inducer fan will bounce up and down.
Old 06-30-2014, 01:34 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
kick that thing around all Ace Ventura style, no worries.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
COLDIRON (06-30-2014)
Old 06-30-2014, 06:46 AM   #5
Rewards Points: 1,214
I have layed hundreds of them on their sides to bang in return air Plenums and ductwork. Never a problem.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 06-30-2014, 01:00 PM   #6
I understand laying on its side to work on it. I'm traveling 200 miles with it in the bed of a pickup.
Old 06-30-2014, 02:39 PM   #7
The best way is on it's back as yuri and been said. If you do travel with it on it's side be very observant when the fan starts if you hear any strange noise shut it down and check the squirrel cage and motor alignment. Go for it.
Old 06-30-2014, 06:09 PM   #8
Hvac Pro
yuri's Avatar
I would prefer it upright.
Old 06-30-2014, 07:20 PM   #9
I'm going to try and leave it upright.
Old 07-01-2014, 06:48 AM   #10
Upright is for Refrigerator's with heaters it don't matter. Maybe a little tiny bit. Believe me when I say that. If your not traveling over a dirt country road for 200 miles I wouldn't worry about it. The bottom line is your doing it your choice.
Old 07-01-2014, 11:11 PM   #11
We ended up leaving it upright. Got it home safe and sound.
Connect AC to Central Air Furnace MaxOvrdrv HVAC 42 05-16-2014 10:50 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
