In-laws A/C Woes - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 08:38 PM   #1
Rewards Points: 77
In-laws A/C woes
Hello Everyone.
I'm sure this HVAC forum is as hot as the weather is with tons of questions so here's another one!
My in-laws A/C won't turn on as per my father in-law. The thermo is commanding cool with the furnace blower running however nothing happening at the condensing unit. It's an old Carrier heat-pump type. I've attached a photo from the internet. Their unit is similar. Just wondering if there's anything I could look at which might be the culprit.
p.s. the circuit breaker is ON.
In-laws A/C woes-current-outside-condenser.jpg
mlijoi is offline   Reply With Quote
Old 06-23-2013, 08:46 PM   #2
Rewards Points: 1,192
Funny all the a/c units troubles are coming from up north. I would push in contactor manualy.
bobelectric is offline   Reply With Quote
Old 06-23-2013, 09:10 PM   #3
Rewards Points: 77
Thanks for the reply!
Ummmm, care to give a bit more info? Where would said contactor live?
Old 06-23-2013, 10:29 PM   #4
Rewards Points: 616
I would not push in the contactor manually......you need a meter to check for power.....
carmon is offline   Reply With Quote
Old 06-23-2013, 11:40 PM   #5
Rewards Points: 50
capacitor is out possibly.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-24-2013, 01:13 PM   #6
Rewards Points: 446
They aren't on some kind of power company interrupt program are they?
Things it could be: No main power at the outdoor unit itself. No low voltage control power getting to the unit. Lost it's refrigerant charge and a low pressure safety switch has it shut off.
If you're helping from a distance I would suggest they call a service person as checking any of the above potentially involves high voltages and the potential for serious injury.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
carmon (06-24-2013)
Water Heater Woes TSHRED56 Plumbing 0 01-23-2011 03:25 PM
Illinois EMT woes... muda7676 Electrical 7 01-16-2011 02:20 AM
CFL Flood Lighting Bulbs Woes (Need Bulb Recommendation) kckc Electrical 9 01-10-2011 05:13 PM
Outlot Laws phospher General DIY Discussions 7 05-21-2009 10:46 PM
Kicthen sink woes.. bzarboni Plumbing 3 03-29-2008 10:31 AM
