Old 08-18-2007, 11:54 AM   #1
Large A/C Sleeve
Hello, I stay in a old building (1960s) and the in wall A/C units are rather large compared to modern A/C units. The sleeve is 42" wide by 16" high. The only units I can find now those sizes are overkill for the rooms they serve both in price and BTUs. Is there a way to install a smaller A/C unit in a bigger sleeve?
uncle_boogaloo is offline   Reply With Quote
Old 08-19-2007, 04:05 PM   #2
Union HVAC Tech.
Large A/C Sleeve
The existing sleeve is proably for a P-Tac unit that heated and cooled the space originally. You can replace the sleeve with a more modern size like a 16" x 26".
bigMikeB is offline   Reply With Quote
Old 08-19-2007, 07:07 PM   #3
Large A/C Sleeve
I'm afraid that's not an option. The building is made of brick, and since it's a condo, they want to maintain the same exterior. So the only way I get a smaller sleeve is if everbody gets smaller sleeves (meaning everyone gets new A/C units).
Should I just get a PTAC unit? Does it require any special connections besides electricity?
Old 08-19-2007, 11:08 PM   #4
Union HVAC Tech.
Large A/C Sleeve
Nope, they slide in the sleeve and plug in. Do you know if any of the units have an original unit?
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
What do you use to reconnect a large gauge wire that was cut? bonedoc Electrical 9 08-10-2007 10:52 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 11:17 PM
Filling a Large Tub Blaze25 Plumbing 2 11-14-2006 07:23 AM
