Laars 110 Endurance Ebp Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 04:48 PM   #1
laars 110 endurance ebp boiler
What would cause my heating zone to overheat room with tstat turned off. could the condensing valve be allowing water to circulate because it is faulty? i have a loop from the boiler that goes thru a plate exchanger where it picks up heat from my outdoor boiler and this wraparound pump runs continously but I don`t see how that could circulate thru the zone with the condensing valve in off position. that loop is just used to maintain nboiler water temp.
pht317 is offline   Reply With Quote
The Following User Says Thank You to pht317 For This Useful Post:
Powerhou se (03-05-2014)
LAARS -Mini-Therm - Residential - Hydronic Boiler JBWARR Plumbing 0 10-17-2011 04:26 PM
LAARS Endurance EBP 110 problem initram HVAC 0 06-14-2011 11:32 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
