Kitchen Exhaust Hood 7" Duct Hookup - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 08:36 AM   #1
Rewards Points: 135
I purchased the Broan QS230 Allure II unit for above my cooktop. The sheetmetal top has a cutout that is 7" round. I plan on running 6" duct. I plan on inserting a 7" start collar, a 7" to 6" reducer with a backdraft damper in that fitting and then going on with 6". Is this the best way to do this install?
smata67 is offline   Reply With Quote
Old 04-05-2012, 08:44 AM   #2
Rewards Points: 314
depends on the route and run of the duct work.
lets say your duct work is only 3 feet long. Then yes, a 6 inch duct would be fine. If your duct is 40 feet long, has a bunch of twists and turns in it, then no a 6 inch would not work.
I would suggest that you research on duct work equivalency. The problem is that every turn or linear foot of duct causes flow restriction and there is a fair amount of difference in the CFM that a 7 inch duct, compaired to a 6 inch duct can move. There are a lot of rules of thumb for ducts and air flow and most will work for you, but you really want to do the reading and make the decision.
btw, why not use a full on 7 inch duct????
bobinphx is offline   Reply With Quote
Old 04-05-2012, 09:07 AM   #3
Rewards Points: 135
7" duct and fittings are hard to find. Also, I have to fit the start collar, backdraft damper, reducer, and two elbows inside of a 24" high cabinet the duct is going through, even 6" may not fit. I only have two elbows and about 6' to the roofline, I don't think getting enough static is going to be a problem.
I'm thinking that I will probably just put a flat sheetmetal plate with a 6" opening on top of the 7" opening and get started right off the bat with 6", it will save me about 4" in the transition piece.
Old Kitchen Brick Exhaust MichaelWayne_71 HVAC 5 12-03-2011 09:22 AM
Water Dripping Out Bathroom Exhaust Hood Caulk? leftygroove General DIY Discussions 7 03-08-2011 07:53 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
exhaust duct 7echo HVAC 4 11-29-2009 12:39 PM
Kitchen Vent Hood Requirements? 4everproject Appliances 1 02-03-2008 07:16 PM
