Old 11-22-2008, 08:31 AM   #1
I have gas!
Clutchcargo's Avatar
Kickspace Heater.
I added a kickspace heater using a monoflow T. I know why it doesn't work and that's because I have to two Ts to close to each other. When I redo it, I'm thinking of ditching the monoflow T and add a valve between the 2 Ts (not monoflow). It seems to me that would work better, I could purge the air easier, and I could throttle the flow to the kickspace. Is my thinking correct or should I go back and make the monoflow T work?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-22-2008, 02:03 PM   #2
I have gas!
Kickspace Heater.
I put a gate valve in between the Ts. Hindsight 20/20, I don't know why I was screwing around with the monoflow T to begin with. Purging was effortless. After I heard all the air leave the heater. I just open the valve about 1/3 of the way and it works perfectly.
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Piping a kickspace heater on its own zone Mike Warner HVAC 5 05-12-2008 12:51 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
