Kerosene Heaters-need General Info. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 03:01 PM   #1
Rewards Points: 22
Kerosene heaters-need general info.
I have a 6 x 10 glass greenhouse and would like to heat it just enough to get that icy winter chill out of the air at night. I am thinking about a portable kerosene heater but know absolutely nothing about them. Are any made that have a thermostat? I want something that will just take the chill out of the air and not to bring it to room temp. I've no experience with these heaters and hope that might be a solution. A portable elect. heater is just too expensive to run. Any advise would be appreciated.
Ronnie1a is offline   Reply With Quote
Old 01-04-2009, 04:08 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
They smell awful and may give off fumes which harm your plants. Some greenhouses use open chimney gas furnaces as the co2 from the chimney is beneficial to plants. Therefore a propane heater would be a good bet. Should be able to shop around and find one with a thermostat. Be VERY careful how you setup ANY heater and leave it unattended. They can tip over or have any variety of weird things happen and cause a fire!! The electric heater is probably the safest bet. Has proper UL safety controls etc. Have seen a few fires in my lifetime and you do not want to get involved with the fire inspector or insurance co by trying to save a few $$.
Old 01-04-2009, 04:36 PM   #3
Rewards Points: 270
What about propane or natural gas...??? Will be much cleaner...
pcampbell is offline   Reply With Quote
Old 01-04-2009, 04:51 PM   #4
And you might check this
http://housing.cce.cornell.edu/f-sht...at%20fuels.pdf
Old 01-04-2009, 05:29 PM   #5
Didn't ever consider that. Interesting, Yuri.
hvaclover is offline   Reply With Quote
Old 01-04-2009, 05:34 PM   #6
Ronnie, do some google searching to get some more info. Years ago, I used one for supplemental heat, messy to refill, and the fumes sneak up on you, nice headache. Also be sure the fuel is readily available in your area. For a your green house, may be the best solution. Mine didn't have a thermostat, haven't seen that on one but wasn't looking either, control the heat by turning the wick up or down.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-04-2009, 07:54 PM   #7
An old Tradesmen
Rewards Points: 7,278
You'll have lots of condensation in a green house, if you only take the chill out.
May be you want it to have 100% RH, may be not.
Old 01-04-2009, 08:39 PM   #8
Remodeling Contractor
These units can be controlled by a plug in thermostat. I use them on construction sites and in my shop. These heaters have an electrical blower also. If your does not, it many standalone units do have thermostats.
Old 01-04-2009, 10:10 PM   #9
Yeah but the upside is 100% efficiency and no flue loss!
how to wire up electrical baseboard heaters mmd21 Electrical 13 12-05-2008 08:11 AM
Kerosene heating issues mikehende HVAC 23 03-29-2008 11:06 AM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
Space Heater And K-1 Kerosene bobo General DIY Discussions 7 10-25-2006 10:38 PM
General contractors license. raymond_anthony Building & Construction 5 08-20-2006 04:07 AM
