Kenmore Refrigerator Not Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 05:53 AM   #1
Unhappy
Kenmore refrigerator not cooling
I have a Kenmore, freezer on bottom, model 596.73912200, and the refrigerator is not cooling. At this post the freezer is not a problem. The fan is running and I feel some cool air in the refrigerator at the bottom which appears to be the vents, but not much.
I have read some of the other posts and I do notice a lot of ice build up on the back wall in the freezer. So I am going to take everything out and turn the freezer off to defrost. I do not know how else to do this as it seems like it is trying to defrost, but the build up is not leaving.
Is this the correct way to defrost...I am DIY challenged and want to try everything I can prior to calling someone to repair....
Thank you so much for any help you can provide!!!!!!!
Fiberartist is offline   Reply With Quote
Old 07-13-2011, 12:41 PM   #2
First of all, try posting this in the appliance section. You will have a better chance of getting the help you need.
VIPlumber is offline   Reply With Quote
Old 07-13-2011, 04:43 PM   #3
Rewards Points: 121
If it works ok after a defrost then I would suspect your defrost heater quit working.
readar is offline   Reply With Quote
Old 07-13-2011, 05:44 PM   #4
Rewards Points: 1,214
Shut it off take the cover off the inside where the frost is get a hair dryer and defrost the coils put it back together and turn it back on. Your problem is the defrost heaters are not working it's probably the defrost timer or the heaters are bad. Kind of hard to trouble shoot if you don't know anything about electrical testing of component's.
COLDIRON is offline   Reply With Quote
Tags
kenmore , nottingham cooloing , refrigerator repair
kenmore fridge/freezer not cooling dmcculley Appliances 0 07-10-2010 11:47 AM
Kenmore side by side refrigerator not cooling bidderbl Appliances 1 09-26-2009 07:48 PM
kenmore 596.58695890 cooling issues mindraven Appliances 7 08-22-2009 09:00 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-23-2008 12:36 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
