Old 07-02-2009, 09:42 PM   #16
hvaclover's Avatar
Originally Posted by bloom42 View Post
I am looking at the parts list and am not seeing anything that looks or sounds like the defrost bi-metal. Is there another name for it?
Defrost termination switch, defrost thermostat, defrost limit.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 07-03-2009, 01:38 AM   #17
OK We have a defrost timer!
bloom42 is offline   Reply With Quote
Old 07-03-2009, 09:50 AM   #18
hvaclover's Avatar
No. That initiates defrost.
Old 07-03-2009, 12:44 PM   #19
Hmm, I can't seem to find that part in the repair parts list. Nothing with the word termination and only "Timer, Defrost" for the word defrost. I guess I will defrost and manually search for the part.
Old 07-03-2009, 02:30 PM   #20
Look for thermostat kit (defrost):
http://www.repairclinic.com/SSPartDe...PartID=1023500
http://www.searspartsdirect.com/part...%20&%20ROLLERS
bluefitness is offline   Reply With Quote
Old 07-03-2009, 11:24 PM   #21
hvaclover's Avatar
You could have an electronic timer in which case you would not need the bimetal.
Old 07-03-2009, 11:56 PM   #22
I referenced his model number for the two parts I posted.
Old 07-05-2009, 08:01 PM   #23
I found a thermostat located inside the ice maker (p/n 627985). It wasn't the same style as the ones referenced above. I am going to test it to see if it is good before I buy it. Does that control the freezer/refer as well?
Could the "electronic timer" be called the "Timer, Defrost"? How would I test this item?
Old 07-05-2009, 08:35 PM   #24
It isn't going to be in the ice maker. It will be clipped onto the evaporator. You have to remove the back panel inside the freezer compartment.
Old 07-05-2009, 09:29 PM   #25
hvaclover's Avatar
You gotta BSing me. This thread is over a month old and you can't/don't want to seem to follow any instruction that's been given.
I think it's an awful big leap going from the freezer to the ice maker and even bigger assumption that you think we will swallow it.
judging by your inability to locate parts in plain sight I think the OP should call a Pro.
With out the right tools and instruments the OP can't do anything.
And any of the methods we pros use to jump out suspect parts would be dangerous for the OP.
Old 07-06-2009, 08:23 AM   #26
NO I am not BSing you. I have appreciated all your and everyone elses help so far. These parts are NOT in plain site I had locate them on the parts sheets then take apart various thing in the fridge to find them. And what directions have I not, or as you say, don't want to follow? You know what, don't answer that. When it becomes this much of a problem for you to help someone out who obviously doesn't know about these things it is no longer help. Thanks again for your willing help in the past. bluefitness thank you very much for the information.
Old 07-08-2009, 10:04 PM   #27
Default could be........
.......a defrost termination control..btw make darn sure the coils under the box are clean , nothing kills a unit faster than plugged condenser coils . they may not look too bad but they are deep and get plugged which causes your operating pressure to go through the roof , kill the cooling , and shorten the life of the frige. also check if u have a little door between the freezer that the thermostat operates for 'fridge cooling . the 'door' should change position in response to the 'stat command.........Jack
psilliman001 is offline   Reply With Quote
More On This Topic
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
The last penalty we're going to show you is unsportsmanlike conduct. Now this happens when you argue with a ref, you make obscene gestures to another player or the ref or even the fans. It also happens if the player's sticks are, the curves are too open... Read More »
Every time you hire a new employee you have to spend time training them and teaching them how to operate in your business. Often times this includes increasing their skill level and product knowledge. While employee retention is not always an easy task... Read More »
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 3 11-04-2009 07:57 PM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-23-2008 01:36 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-23-2008 12:52 AM
Kenmore Icemaker install Turnerg110 Appliances 2 07-21-2008 05:55 PM
Fridge not cooling - evap fan? oppiecat Appliances 3 12-06-2006 08:46 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
