Keep Falling Ice Off Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 10:21 AM   #1
keep falling ice off hvac
how to build a roof for a HVAC unit to keep ice from falling on it
proeme is offline   Reply With Quote
Old 03-03-2011, 04:00 PM   #2
Rewards Points: 120
Build it in the Bahama's?
Old 03-03-2011, 04:28 PM   #3
An old Tradesmen
Rewards Points: 7,816
It need to be at least 5 foot above the unit, some makes want more.
Old 03-03-2011, 08:41 PM   #4
Rewards Points: 6,652
Not if only needing it during the Winter when the thaw happens, and the unit does not need to be ran if not a Heat pump.
Old 03-03-2011, 08:43 PM   #5
If it is damaging the unit, and it is not a Heat Pump, you can lay a piece of 1/2" to 3/4" Ply on top to protect it. If a Heat Pump, then you may want to talk to a roofer about looking into why you are getting ice freezing on your roof during Winter. If the roof is properly insulated from the living spaces, you should never get Ice. If living up north where you get huge amounts of snow fall, get a snow rake to remove the snow during the season, and use a piece of ply on the unit to protect if not a heat pump.
Old 03-04-2011, 03:50 AM   #6
An old Tradesmen
He said build a roof. Implies its going to be there summer and winter. In summer he'll want to run the A/C, so it needs to be built high enough not to interfere with air flow.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 10:47 AM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 04:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
HVAC Ceiling vent falling off, how to fix? guile Building & Construction 4 01-20-2009 02:44 PM
