Just For Troubleshooting Fun.... - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 04:54 PM   #1
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Just for troubleshooting fun....
Was on a troubleshooting call today for a AC unit running with a call for heat...
Any guesses what would cause this?
Old 06-29-2012, 05:00 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
My first guess would be a bad reversing valve coil.
When you say "call for heat" bad thermostat or improperly programmed stat.
wirenut1110 is offline   Reply With Quote
Old 06-29-2012, 05:21 PM   #3
E2 Electrician
This was a single stage AC unit, no heat pump involved.
Old 06-29-2012, 06:31 PM   #4
Bad thermostat,thermostat wires shorted or a sequencer stuck closed.
Old 06-29-2012, 06:40 PM   #5
E2 Electrician
I will add this, it is a simple solution, and remember, only when in HEATING mode and calls for heat does the AC kick on.
Old 06-29-2012, 07:05 PM   #6
HP thermostat instead of a heat/cool? What I really want to know is where are you?(still running heat on June 29th)
Old 06-29-2012, 07:14 PM   #7
E2 Electrician
To fill in the blanks, a heating contractor got a trouble call over the winter for the AC unit and the heat running at the same time, he couldn't find the problem so he removed the Rc, Rh jumper and then came summer... It was on my list of things to check out, after examining the air handler I knew the problem was in the tstat, after removing it, I looked at the back of the unit and the HP / NORM switch was in the HP mode... not sure why the heating contractor didn't find this, but it probably really messed with him since heat pumps are just starting to become more popular in this area and most are inexperienced with how they operate.
