Just Replaced Capacitor But Air Not Cold Anymore - HVAC - DIY Chatroom Home Improvement Forum
Old 08-05-2008, 09:43 PM   #1
Question
Just replaced capacitor but air not cold anymore
Hi,
I just replaced the capacitor on my Goodman CKL 36 outside unit because it was bloated and the compressor and fan wouldn't start.
Now both the compressor and fan are running and its cooling again but not as it was before this event. I've been running it all day but the house won't cool below 80 degrees. (I've got target temp set at 74). It used to cool to 74 within an hour.
Any ideas? Did the capacitor failure maybe mess something else up or is this just a coincidence? (It's been ~100 degrees every day here in Memphis for a while)
Thanks for any help or advice!
-JT
traynor is offline   Reply With Quote
Old 08-05-2008, 09:45 PM   #2
Maybe if it failed by shorting, rather than if it failed by opening or by changing value; if you still have the old cap you could check it for a short.
Old 08-05-2008, 10:13 PM   #3
not sure about shorting
I left the dead capacitor at the parts house.
Everything's been running well for 10 hours it's just not cooling the house below 80 degrees anymore.
Could you elaborate?
Thanks,
-JT
Old 08-05-2008, 10:29 PM   #4
[quote=traynor;146256Could you elaborate?[/quote]
Well, maybe a shorted cap could ruin a winding in the compressor. You'll need a clampon ammeter to check compressor current draw, and compare it with specs.
But before you do all that, HVAC people on this forum can probably come up with many things that are easier and quicker to check, that could account for your symptoms.
Even if some of the checks are unlikely to uncover the problem, if they are quick and easy and safe to do, at least they can tell what it isn't.
Since you just worked on this, I'd say retrace your steps and find the connector you left off, or accidentally pulled off.
You might need a pair of fresh eyes to see something that you are looking at but not seeing.
Old 08-05-2008, 11:09 PM   #5
Roger that.
Anyone else want to chime in? We're ready with a multimeter...
Otherwise, I took a photograph of the connection before removing the old capacitor and replaced the new one with all the wires in the exact same places. Would it run like it is now if I hadn't put them all on the right connectors?
Old 08-06-2008, 11:07 AM   #6
You may be over thinking the problem here. If the compressor and condenser fan is running continuously with the new capacitor, then I highly doubt that is the issue. Is your suction line cool or cold to the touch? What is the temperature difference between return air and supply air when the AC is running? Sounds more like a refrigerant issue than a capacitor issue in my experience.
statman is offline   Reply With Quote
Old 08-07-2008, 12:15 AM   #7
Thumbs up
Ok- it was just heat saturation
Hi Guys - after sundown it all cooled better and today everything works well.
It just took a long time because the house was so hot (!!!) It's nearly 100 degrees every day here in Memphis....
thanks for your help!!!
-JT
Old 08-07-2008, 09:24 AM   #8
-JT
So do you think the cap was bad, after all?
Old 08-07-2008, 04:54 PM   #9
Cool
The capacitor was definitely bad
It had a bubble swelling out of the top where the wire connectors were.
That's why the whole system shut down to begin with and my house got so hot that I had to cool it for 24 hours!
Cheers!
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 11:50 PM
