Old 06-04-2012, 09:50 PM   #1
Just a question...
Was informed the pressure ratio between the high side and low side should be roughly 3:1... What would be some causes if the pressures were closer to 2:1 or 4:1?
Hvacwin is offline   Reply With Quote
Old 06-05-2012, 12:01 AM   #2
Just a question...
Never heard people measure that way. If off to 2:1 or 4:1 as you said, is the high side off or low side off ? huge difference there. (Anyway, 3:1 is close to normal, but not always) (R-22 ? I assume )
clocert is offline   Reply With Quote
Old 06-05-2012, 05:59 AM   #3
An old Tradesmen
Just a question...
A 4:1 compression ratio may just be indicating a high load at the start up of the system. A 2:1 would be an indication of a weak compressor, or RV leaking through, or an over sized piston/metering device.
A lot of higher efficiency units will run lower then 3:1.
Old 06-05-2012, 08:44 AM   #4
Just a question...
How are you performing the calculation? Are you remembering to use absolute values? If not, that can really throw off your result.
HVACDave is offline   Reply With Quote
Old 06-05-2012, 05:16 PM   #5
An old Tradesmen
Just a question...
Need to add 14.7 to the gauge reading. or what ever your altitudes atmospheric pressure is.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
