Just Had Compressor Replaced, But Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 08:33 AM   #16
The Tech came out yesterday and checked the pressure. He was here about 45 minutes with the gauges hooked up and said everything looked good, but he didn't stay long enough for the compressor to cut off. It cut off a little while after he left.
He came back today and replaced the dual capacitor. Old one was 40uF, he said it should be 45uF. The old one had been in there for around a year(replaced by a different company).
So, hopefully this will fix the problem, what do you guys think?
Fisher252 is offline   Reply With Quote
Old 07-28-2011, 12:56 PM   #17
Pressure alone will not tell you if charge is correct. Did he measure superheat and/or subcooling? I don't know for sure, but do not believe increasing the capacitance 12.5% amounts to a hill of beans; however, you are supposed to stay within 10% so the tech was right to replace it. Now, if you had a 30 or 35uF and the compressor called for 45uF it would be different. Of course it is possible that your compressor was overheating at 35uF, but I guess you will find out. I would add to what others have already said. You should do your best to find out why the original compressor failed.
artbuc is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
