Just Got Quote For Replacement HVAC System - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2008, 01:37 PM   #1
Just got quote for replacement HVAC system
Wanted to run this by you guys.....just had one of the bigger companies in Charlotte, NC come out and give me a quote on replacing a 23 yr old Trane 2 1/2 ton heat pump and handler. First of all the guy quoted me on the exact same thing I have without doing any kind of (load test I think) just looked on the lable of my old unit and quoted based on that....2nd the quote was for 7500 bucks for a 2 1/2 ton 13 seer comfortmaker. Does this sound right....sounded super high to me but not sure.
dcheek20 is offline   Reply With Quote
Old 01-26-2008, 01:49 PM   #2
Eibwen
If it were just the heat pump I would say yes its high but you say he also quoted on replacing the air handler.
I would get one-two more quotes from local reputable companies on the same replacements to drive it to scale and see if they are in line.
Sammy is offline   Reply With Quote
Old 01-26-2008, 03:08 PM   #3
Sammy,
Ok thanks a lot.....Should I consider switching to a package unit...not sure if it will save money.
Old 01-26-2008, 03:15 PM   #4
Eibwen
Your welcome.
Might get a seperate quote on a package unit and compare the long term operating cost between the two.
Old 01-26-2008, 05:31 PM   #5
Union HVAC Tech.
Going to a package unit would involve way more duct work, so it would cost more. What would you gain with a package? More space where the air handler is? Service call without being home? There are advantages. I would get a couple more quotes. As for sizing on a replacement, when most salesmen come out to give a price they would ask if you were happy with the preformance of the old unit, if it worked fine they would just quote the same outputs.
bigMikeB is offline   Reply With Quote
Old 01-26-2008, 05:38 PM   #6
Eibwen
If Big Mike says that then I agree... He knows the business and what he is talking about!
Old 01-26-2008, 09:26 PM   #7
Watch for rebate deals soon. March or so I think. And if you haven't used your energy tax credit yet you can get up to $500 tax credit, but you have to have at least 15 seer I think and 95% effeciency for heat. I upgraded my system spring of 06 and got a $1000 rebate and $500 tax credit.
aace is offline   Reply With Quote
Old 01-27-2008, 11:29 AM   #8
I just saw that the tax credit expired Dec 31, 2007. There is talk of renewing it for 2008.
http://www.energystar.gov/index.cfm?...pr_tax_credits
Problems with Central Air Cooling System golfgod04 HVAC 4 05-27-2007 08:51 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 05:59 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 06:04 PM
Insulating an attic for HVAC system BigJimmy Building & Construction 7 10-07-2006 09:10 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
