Old 05-15-2012, 12:31 PM   #1
Just drilled through a baseboard heating line - ugh
I swear, only me. Luckily it only leaked into the garage.
I managed to find the valve coming out of the boiler to shut it off, and thankfully it's starting get warm out so hopefully there's no rush in fixing this zone (which means I can DIY).
But assuming I can get to the pipe, cut out the part I drilled through, and replace it, what am I looking at doing to refill it? Just turn on the valve, let it fill, then bleed at the baseboards? Do I need to add anything to the water? If I have a pro do this, what's a ballpark $ (located in the northeast...we talking $200 or $2000?)
Thanks. Sometimes I wish I didn't own tools.
Proulx06 is offline   Reply With Quote
Old 05-15-2012, 04:10 PM   #2
Missouri Bound's Avatar
Cut out the damaged part and repair it. Turn the valve back on and open the bleeder. Your boiler will have a fill valve which regulates the amount of pressure in the system. When water comes from the bleeder, close it.
Do you want it your way or the right way?
Old 05-15-2012, 08:21 PM   #3
biggles's Avatar
how big was the bit and drill hole?right thru it or just into it.that is just circulated water maybe 20psi when hot during the winter just access the pipe and lets hear back.might not need to ripe out the pipe but fix in place
biggles is online now   Reply With Quote
Old 05-15-2012, 08:26 PM   #4
biggles took the words out of my mouth..how big is hole and did you go all the way through....????? maybe you could just silver solder it....????
Old 05-16-2012, 09:15 AM   #5
biggles's Avatar
a turbo torch and small tip hittting it with a rod your done..smaller hole stay brite or solder 95/5 will do it also...sand it flux it...
Switching from Oil Heat to Electric Baseboard Heating - Recommended? younglandlord Plumbing 3 06-24-2010 09:49 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
the best way to piping baseboard water heating alan25 Plumbing 1 01-31-2010 09:05 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Baseboard Heating Stops Getting as Hot as it Used To? kali Plumbing 7 02-12-2009 04:08 PM
