Joint Type/leak Help (heat Exchanger) - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 05:25 AM   #1
Joint type/leak help (heat exchanger)
Hi,
UnfortunatelyI've got a leak from the output of the condenser heat exchanger on my Heatline Vizo 24. Please could someone ID what kind of joint this uses from the attached photo as I cant seem to be able to find out using the powers of google (and the installation manual is no use).
Any advice on how to stop the leak would also be welcome!
Thanks in advance.
Joint type/leak help (heat exchanger)-imag0441.jpg
Bob_uk is offline   Reply With Quote
Old 02-07-2012, 05:51 AM   #2
DIY staff
Rewards Points: 7,174
Bob--I am going to move this to HVAC for you--that looks like a heating and cooling question to me---
Bob_uk (02-07-2012)
Old 02-07-2012, 06:02 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 92
has some type of pull tab locking the bottom pipe to the top unit. may have 0-rings or teflow seals or other type of method to seal it. may have to get a Pro who knows that unit to drain it and fix and refill it properly.
Old 02-07-2012, 06:12 AM   #4
Ravenworks's Avatar
That is an expansion joint.
The fitting should have an "O" ring that is retained by a clip.
Ravenworks is offline   Reply With Quote
Old 02-07-2012, 06:38 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 92
judging by the discoloration of the pipe it must be getting very hot. some o-rings are rubber and better quality ones are silicone and may look like rubber but are rated for higher temps. may need to check into a better grade of o-ring.
Old 02-07-2012, 07:57 AM   #6
RTV no work-ee this time Yuri? Never seen one of those before. It' a Vizo...so I guess it's Asian.
hvac5646 is offline   Reply With Quote
Old 02-07-2012, 08:04 AM   #7
Hey Yuri...did that leaker look like a solder attempt had been made to it?
Looks like somebody smoothed out a solder connection with wet rag.
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Repair or Replace 13 yr old Furnace with Cracked Heat Exchanger Thor73 HVAC 33 11-12-2011 08:14 PM
Trane XL90 heat exchanger Lizardking HVAC 2 11-01-2011 08:44 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Checking for suspected crack in heat exchanger Kozzy49 HVAC 8 12-01-2009 08:16 AM
