Jenn-Air Downdraft Cook Top - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 12:47 PM   #1
Smile
Jenn-Air downdraft cook top
Hello, I'm installing a Jenn-Air downdraft cooktop as per instructions, problem is, I live in one of the colder regions of Canada and I'm really not sure how to install the outside vent and ducting for the extreme cold.
Trying to find an outside vent (not the cheap plastic ones) that will close with a good seal, haven't had good luck with the plastic vent sealing tightly, at least on the dryer.
I heard of other people installing the cooktops and having frost work its way back to the blower motor.
Any takers of this.
Best regards
J willis
jwillis9 is offline   Reply With Quote
Old 09-29-2008, 01:01 PM   #2
ccarlisle's Avatar
Can't help you find one but we have a metal vent with a spring-loaded flap that seals tightly shut even in winter but still, the floor gets awfully cold around the vent.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 09-29-2008, 01:03 PM   #3
What brand is it.
John
Old 09-29-2008, 08:32 PM   #4
30 year tech
hvac122's Avatar
Jen-Aire has there own cap that they want you to use. Ask the people where you bought it. It is plastic if I remember correctly but is spring loaded with a seal.
hvac122 is offline   Reply With Quote
Old 09-29-2008, 10:28 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I installed a Jenn-aire in my kitchen about 12 years ago, I used their vent cap, there's no backdraft at all, even in a stiff wind.
It gets down to about 10F around here, and the wind can get up to 60 MPH regularly.
The dryer vent.......well, it's a bit more drafty.
Rob
micromind is offline   Reply With Quote
GE cook top instalation question sninny Appliances 1 07-28-2008 06:21 PM
