Janitrol Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 08:04 PM   #1
Janitrol furnace
We have a Janitrol furnace model GMP100-3. We noticed it would sound like it was starting up but then would cut out. This would happen 5 - 6 times and then it might run ok for 10 minutes and then shut off, repeating the process again. We were told to turn the power off for 5 minutes to see if that worked - it didn't change anything, so we replaced the thermostadt. We figured out we installed the wrong thermostadt and several days later put in the correct thermostadt. Now we can get the blower to come on, but the igniter doesn't light, so the air blowing is cold. What else might we try before giving in and calling a technician?
twoDIYers is offline   Reply With Quote
Old 02-19-2011, 08:29 PM   #2
put the old stat back on and see if it lights then.
hvaclover is offline   Reply With Quote
Old 03-14-2011, 11:25 PM   #3
I have a very similar issue with the same furnace. When I turn on the heat, the inducer blower goes on, then off, then on, and will sometimes eventually stay on. Although with mine, the furnace actually lights if the whole thing doesn't cut out, and once it's on, it stays on.
humdinger0102 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
janitrol furnace keeps shutting off terrylyn11 HVAC 10 01-24-2010 10:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Janitrol 20-125 gas furnace will not fire flatlander745 HVAC 1 11-09-2008 07:22 PM
