It's Cold Already...furnace Not Working :( - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 06:57 PM   #1
It's cold already...furnace not working :(
I have a Lennox that's approx. 10 years old and with the cold weather coming here in Iowa I turned the gas furnace on the other night and nothing came out but cold air. It has an intermittent pilot ignition system on it and it was not even attempting to ignite. Long story short I changed the Sensor and the ignitor and still nothing. I don't even smell gas when the valve is on. My hot water heater and stove are working fine so why am I not smelling gas if the system is on. Thanks guys in advance.
bryangwilson is offline   Reply With Quote
Old 09-09-2008, 10:46 PM   #2
troubleshooting
Ideally you should never smell gas. Do you have around 24 volts at the W terminal in the control box when calling for heat? If not, maybe check the transformer. Just a thought from a newbie. Hope it helps.
hvac newbie is offline   Reply With Quote
Old 09-09-2008, 11:33 PM   #3
thanks
I don't have a tester to check the volts. I'm thinking that it's the control module. Those are about $200 I think.
Old 09-09-2008, 11:51 PM   #4
I think you had better find a professional tech!
Old 09-10-2008, 08:59 AM   #5
If you don't have a volt meter and other tools you need to call a HVAC tech. You can however check some simple things such as an obstructed air intake or exhaust if this is a high efficiency unit. Bees and kids love to build and put things in PVC pipes.
dac122 is offline   Reply With Quote
Old 09-11-2008, 05:44 AM   #6
biggles's Avatar
if you have no spark on the stat mercury or LED on a digital or any action within the air handler(but fan runs) with that you have at least 24V control.pull the stat and jump as suggested R to W see if that gives you pilot action.emergency switch ON away from the burner?stat set for heat..sorry had to ask
Carrier Furnace - out cold :) cheddarhead HVAC 30 04-23-2012 01:23 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 07:51 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
