Its Been A While Since Ive Done This - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 03:13 PM   #1
its been a while since ive done this
which line is suction and which is liquid. And which line do you shut to pump the freon back into the compressor
garybrack is offline   Reply With Quote
Old 06-13-2011, 03:37 PM   #2
JJboy's Avatar
Liquid line ( small line )
Suction Line ( large line )
You close the service valve at liquid line.....and pump down until you get 0 psig on the gauges. After that close the service valve at suction line.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-13-2011, 05:20 PM   #3
biggles's Avatar
if you have a total vacuum on the entire system dump into the LL let it equalize flip the can again remove the guage hose and start the system let it run and then add gas only to the insulated larger line at the compressor...should be a shradder valve on those servcie valves both full CCW open to the system running you don't need to work the valves just the shradder taps
