Invasion Of The Birds - Bathroom Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 09:53 PM   #1
Rewards Points: 81
Invasion of the Birds - Bathroom Vent
I removed the old attic fan since it has not been used in about 10 years since I got central air. It also sounded like a freight train. I've had it stuffed with insulation and covered with plywood for years to prevent heat loss, so the current living room paint/floor project means its time to seal it up right.
While I was up there I discovered birds have invaded the gable vent and bath fan exhaust. See the attached picture. While I have an extra large hole in the ceiling, it is time to fix it.
I believe the proper way to fix this is to cut a hole in the roof and vent directly up. I don't do roofs, and really don't want to hire someone to do it right now with my other expenses, so I would much rather vent out the gable again.
I know I should use aluminum vent pipe and angle it down towards the outside so any condensation runs out instead of breeding mold. Obviously I need to repair the screen on the gable vent. I also figure I might as well replace the fan as Murphys law says it will fail next week if I don't.
The fan is about four feet from the gable vent, so it is not a very long run.
What is the best screening to use to prevent future critter invasions?
Is it OK to use flexible aluminum duct, or should I go with rigid?
Any fan recommendations? The existing is a Broan Nautilus, about 9x10" light/fan combo. It is 20+ years old. Bathroom is about 9x7'.
Thanks for any advice.
tev9999 is offline   Reply With Quote
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
Bathroom Rough-In- Mystery Vent flyboy Plumbing 10 04-10-2012 09:37 PM
Wrong roof vent for bathroom exhaust? vanishingson Roofing/Siding 18 04-04-2011 06:25 AM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
