Intertherm Oil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 12:00 PM   #1
In following the directions for for the seasonal firing up. They say to place a jumper on terminals FF. When doing this the furnace fires just fin and will stay lit for as long as the jumper is on. I suspect this is a thermostat by-pass. When I try to use the thermostat the furnace does not start thr furnace. I suspect the thermostat which is older then the furnace is malfunctioning.
eatjerkyhut is offline   Reply With Quote
Old 11-02-2010, 07:32 PM   #2
An old Tradesmen
Rewards Points: 7,414
FF stands for Flame Failure. When you jump it out. You are bypassing the flame failure safety.
Generally, that is only done when bleeding the pump. And should not be done any other time.
Your thermostat connects to the TT terminals. Which stands for thermostat.
So are you pressing the reset button, and then jumping the FF terminals.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Operation of Intertherm downflow furnace. deerslayer HVAC 5 12-03-2009 07:13 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
