Intertherm Furnace Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 01:18 PM   #1
Intertherm furnace replacement
I am replacing a intertherm furnace in a modular with a intertherm furnace do I need to replace the venting and roof jack or can I just reconnect them and if I do need to replace them why is that, I don't deal much with modular furnaces usually just deal with standard residential equipment
heatycooly is offline   Reply With Quote
Old 12-11-2011, 03:43 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
talk to Intertherm. probably need to replace them. they are VERY finicky when it comes to venting. may cause pressure switch tripping problems and lighting problems if you don't. has to do with the amount of combustion air that enters thru one of the pipes and back pressure on the other. uses a concentric vent setup from what I have seen.
Old 12-11-2011, 03:49 PM   #3
Kinda what I figured the old one is a concentric as well but one natural draft to induced draft now
Inducer motor replacement on a payne furnace exintrovert HVAC 6 07-02-2010 07:07 PM
Furnace combustion chamber replacement tripower HVAC 2 10-21-2008 06:39 PM
Relocate furnace (replacement) to attic? AppleMac*Fit HVAC 10 01-13-2008 06:11 PM
Furnace Replacement Options? Genhawk21 HVAC 5 01-11-2008 09:41 PM
best oil furnace replacement option crossthreaded HVAC 3 01-18-2007 08:47 AM
