Intertherm Electric Furnace Will Not Stop Running - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 09:02 AM   #1
Intertherm electric furnace will not stop running
I have an old Intertherm electric furnace model: MAC 2454A. It will not stop running. Two years ago the heating element would turn off but the fan kept running at which time I installed a new sequencer and that fixed the problem. Now neither the heater element nor the fan will stop running. I have disconnected the thermostat which made no difference. Any ideas to what might be causing this?
moundtown is offline   Reply With Quote
Old 01-24-2013, 05:53 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
fan relay/contactor is stuck.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-24-2013, 06:09 PM   #3
An old Tradesmen
Rewards Points: 6,498
Sequencer stuck closed.
Old 01-24-2013, 06:27 PM   #4
Sequencer is stuck closed.
blingbling is offline   Reply With Quote
Old 01-24-2013, 06:56 PM   #5
Thanks all. Diagnosis seems to be unanimous, and as it turns out, correct as well. I removed the sequencer that I had installed just the winter before last and it tested bad. Replaced it with a new one and the problem is solved.
Sears GAs furnace issue with burner running too long dmanmtl HVAC 17 01-03-2012 10:41 PM
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 09:38 AM
New Coleman oil furnace, won't stop running Loni HVAC 11 10-16-2010 07:40 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
