-   -   Intertherm electric furnace will not stop running (http://www.diychatroom.com/f17/intertherm-electric-furnace-will-not-stop-running-169983/)
moundtown 01-24-2013 08:02 AM
I have an old Intertherm electric furnace model: MAC 2454A. It will not stop running. Two years ago the heating element would turn off but the fan kept running at which time I installed a new sequencer and that fixed the problem. Now neither the heater element nor the fan will stop running. I have disconnected the thermostat which made no difference. Any ideas to what might be causing this?
Doc Holliday 01-24-2013 04:53 PM
fan relay/contactor is stuck.
beenthere 01-24-2013 05:09 PM
Sequencer stuck closed.
blingbling 01-24-2013 05:27 PM
Sequencer is stuck closed.
moundtown 01-24-2013 05:56 PM
Thanks all. Diagnosis seems to be unanimous, and as it turns out, correct as well. I removed the sequencer that I had installed just the winter before last and it tested bad. Replaced it with a new one and the problem is solved.
