Intermittent Pilot Stays On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-08-2014, 10:21 AM   #1
Question
I don't want to fix this myself, but I do want to educate myself on the source of the problem before I call for a service tech.
I have a Slant/Fin Galaxy GG125 boiler (installed 1985) that has an intermittent pilot light. At least, it used to be intermittent!
For the past few days, the intermittent pilot has been staying lit 24/7, after the main burner shuts off.
The pilot even stays lit when I switch the knob on the gas valve to "off".
If I shut the main gas supply off, it goes out. When I start it up again after this, it sparks, pilot lights, and main burners come on. However, when main burners shut off, the pilot stays on again indefinitely.
Boiler is otherwise cycling properly.
Is this a defective intermittent pilot control? Or a defective gas valve?
GeorgeHC is offline   Reply With Quote
Old 04-08-2014, 11:27 AM   #2
how
Rewards Points: 1,104
The gas valve should not allow the pilot to remain lit when mechanically turned to the off position. If you are sure that you have moved the gas valve control to the off position, and the pilot remains on....
change the gas valve.
how is offline   Reply With Quote
Old 04-08-2014, 03:52 PM   #3
Rewards Points: 582
yes agree with how ..if knob was turned to off position and pilot stays on ....replace gas valve...no way should a pilot stay on with intermittent ignition system
The Following User Says Thank You to ben's plumbing For This Useful Post:
GeorgeHC (04-11-2014)
Old 04-09-2014, 01:50 PM   #4
Sticking gas valve? Or faulty control?
Thanks for the feedback.
Ok - I just double checked and it looks like I did not shut the gas valve knob control all the way off the first time. When I shut it all the way off, the pilot does indeed go out.
But the pilot flame is still staying on continuously between cycles, when there is no call for heat.
I experimented by blowing out the pilot flame. The pilot valve stayed open, and gas continued to flow despite the lack of flame. This continued for about 30 seconds, until I re-lit the pilot manually with a match.
The valve is a White-Rodgers 36C84, Type 201, with a White Rodgers 3098-134 Automatic Pilot flame sensor that plugs into it.
Old 04-09-2014, 04:56 PM   #5
An old Tradesmen
Rewards Points: 7,414
Most likely gas valve. To check, use a multimeter to see if you have 24 volts going to the gas valve's pilot terminal. if not, its the gas valve, if you do, its the control.
Either way, you have an unsafe unit, and should shut the gas off until fixed.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (04-09-2014), GeorgeHC (04-11-2014)
Tags
control , gas valve , pilot
Intermittent pilot assembly problems! clogistics HVAC 2 01-19-2013 08:13 PM
Can a standing pilot use electronic ignition? richapple HVAC 20 11-26-2012 11:45 PM
Bryant 394J Furnace - Pilot stays ON all the time Davexxx HVAC 17 04-08-2012 06:46 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
pilot light stays on when it shouldn't hvac novice HVAC 1 11-02-2007 12:38 AM
