Intermittent Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 12:33 PM   #1
Rewards Points: 101
Intermittent Fan
I like to run the fan constantly to circulate air in my home; I just have the fan switch set to "On" Recently, I've noticed that the fan cuts out periodically. I did some troubleshooting and it appears that the problem only occurs when the fan's running from the "fan on" switch since it never cuts out when the heat is actually running.
What could be wrong?
michaelson is offline   Reply With Quote
Old 10-20-2013, 03:54 PM   #2
An old Tradesmen
Rewards Points: 7,414
Does it do it just before the air becomes warm? If so, its programmed into the board to do that.
Brand and model number of furnace may help.
Old 10-20-2013, 10:13 PM   #3
Rewards Points: 101
No, it happens constantly. It's clearly broken, in 10 minutes it cycled probably 20 times. I will check the model number when I get home.
Old 10-21-2013, 12:55 AM   #4
Rewards Points: 101
Carrier Weathermaker 8000
Old 10-21-2013, 04:14 AM   #5
An old Tradesmen
Check if the wire from the G terminal of the thermostat and at the furnace is loose.
Old 10-21-2013, 07:33 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
the switch for fan ON at the thermostat may be weak and not making good connection.
Old 10-26-2013, 09:08 PM   #7
Rewards Points: 101
It's not a loose wire, I checked all the wires and they're tight. Is the thermostat user replaceable or do I need to hire it in?
Old 10-26-2013, 10:57 PM   #8
An old Tradesmen
You cn do the thermostat yourself.
Intermittent Beckett Oil Burner needs reset every day nick26 HVAC 14 02-11-2013 05:15 PM
xv80 intermittent blower problems drmiller7 HVAC 2 03-05-2012 05:01 PM
Intermittent furnace lockouts, fouled nozzles, combustion air, and cold basements rodney23 HVAC 6 02-13-2011 09:38 AM
Intermittent Low Pressure, "Sluggish" Pump Sound, Well wcp Plumbing 3 06-27-2010 02:50 PM
Bryant plus 90 intermittent ignition miguy HVAC 2 04-11-2010 10:31 AM
