-   -   Intermittent Fan (http://www.diychatroom.com/f17/intermittent-fan-188869/)
michaelson 10-20-2013 12:33 PM
Intermittent Fan
I like to run the fan constantly to circulate air in my home; I just have the fan switch set to "On" Recently, I've noticed that the fan cuts out periodically. I did some troubleshooting and it appears that the problem only occurs when the fan's running from the "fan on" switch since it never cuts out when the heat is actually running.
What could be wrong?
beenthere 10-20-2013 03:54 PM
Does it do it just before the air becomes warm? If so, its programmed into the board to do that.
Brand and model number of furnace may help.
michaelson 10-20-2013 10:13 PM
No, it happens constantly. It's clearly broken, in 10 minutes it cycled probably 20 times. I will check the model number when I get home.
michaelson 10-21-2013 12:55 AM
Carrier Weathermaker 8000
beenthere 10-21-2013 04:14 AM
Check if the wire from the G terminal of the thermostat and at the furnace is loose.
yuri 10-21-2013 07:33 AM
the switch for fan ON at the thermostat may be weak and not making good connection.
michaelson 10-26-2013 09:08 PM
It's not a loose wire, I checked all the wires and they're tight. Is the thermostat user replaceable or do I need to hire it in?
beenthere 10-26-2013 10:57 PM
You cn do the thermostat yourself.
