Intermittant Burner Operation On A '83 Bryant - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 06:44 PM   #1
Intermittant burner operation on a '83 Bryant
So, I have troubleshot this furnace every way I know how to and I cannot find a reason for this problem.
The furnace operates normally and will go through the entire sequence just fine. However, occasionally the burners will suddenly extinguish before the thermostat is satisfied, and the gas valve will continue to release gas into the combustion chamber for a good 7-10 seconds. Then the valve will close and about 20 seconds later the furnace will re light the pilot and seem to operate normally. Sometimes this reignition of the pilot will cause a significant rollout. Any ideas why this might be happening?
I did a full clean and check on this thing. I did not visually see a hole in the heat exchanger, and when the blower comes on there is no flame waver, and i can fire the main burners with the blower running without a rollout. I cleaned out all the burners and spuds. I ran through practically the entire wiring diagram with a meter, checking continuity and voltages and making sure they were good. No loose connections, nothing. Its not going out on high limit because I checked the limit switch just after the flames extinguish and it wasnt open. Anyone have any ideas or things I might check? I've been meaning to check the outlet pressure of the valve but I havent had a chance to get to it yet.
okaycomp is offline   Reply With Quote
Old 02-14-2010, 06:53 PM   #2
An old Tradesmen
Rewards Points: 7,830
Have you checked your flue/chimney?
Old 02-14-2010, 08:18 PM   #3
for an obstruction?
Old 02-14-2010, 08:24 PM   #4
An old Tradesmen
Originally Posted by okaycomp View Post
for an obstruction?
Yep.
Dirt, birds, squirrels, rodents, etc.
They like to warm up sometimes. But they fall asleep and die from the fumes.
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
Bryant Pilot Burner modemjim HVAC 2 12-13-2008 01:17 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 12:57 PM
