Old 12-30-2012, 07:19 AM   #1
Interesting products... your thoughts...
Hi all,
What do you think of these products....?
1) "T-Eco"... on demand defrost for heat pump http://www.abchybrid.ca/index_files/Page1360.htm
2) "3-FLEX" ... Controller for an add on electric plenum heater
http://abchybrid.ca/index_files/Page638.htm
I don't think the savings are that high.
Here in Quebec, home heating oil is approx $1 liter ($3.90 US gallon).
And that electricity is cheap here (dual enery DT rate):
Warmer than -12C(10.4F) the price is 4.3 cents/KwH
Colder than -12C(10.4F) the price is 20.4 cents/KwH
Most of the time it is warmer than -12C(10.4F) therefore we want to electric heat as much as possible.
The defrost cycle of the heat pump uses oil to speed up the process. We don't want that!
In my case the heat pump puts out approx 38C(100F) heat. But it can drop to 30C(85F) - 32C(90F) by the time it gets to the bedrooms (becasue it's a long skinny house and the duct is over 50ft long). So the plenum heater would help the heat pump (but not when colder than -12C(10.4F)).
Cheers!
Terry
tls1 is offline   Reply With Quote
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Has anyone every used the sikkens cetol products? choppermrt General Discussion 3 06-11-2010 06:43 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
Thoughts on Pergo Select and Wilsonat Estate flysndoc Flooring 5 01-24-2007 01:13 PM
US Coatings products Brian Burns Painting 8 12-15-2006 11:40 PM
