INTake For HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 11:26 AM   #1
INTake for HVAC
Looking for advice: I have realized in my new home, the intake for the HVAC system is routed to the fireplace. I'm haveing a new fireplace put in and want to remove the bulky duct work on the basement ceiling. Should I just remove the duct work and add a vent the pulls in air from the basement,(since the basement will be finished in 6 months? Or should I have the duct work rerouted to take in air from the the upstairs? Attached is a picture to give a visual of what it currently looks like. INTake for HVAC-remodeling.jpg
bladesj is offline   Reply With Quote
Old 07-25-2009, 11:04 PM   #2
as seen on tv
Rewards Points: 150
Not a good idea, Your system will not function correctly. Airflow will suffer. To have a good balanced system a return air path is needed for every room that is supplied with conditioned air. From your pic the return ducting will have to be larger than the supply, the way it is set up now
qbert is offline   Reply With Quote
Old 07-27-2009, 12:35 AM   #3
no returns......
Originally Posted by bladesj View Post
Looking for advice: I have realized in my new home, the intake for the HVAC system is routed to the fireplace. I'm haveing a new fireplace put in and want to remove the bulky duct work on the basement ceiling. Should I just remove the duct work and add a vent the pulls in air from the basement,(since the basement will be finished in 6 months? Or should I have the duct work rerouted to take in air from the the upstairs? Attached is a picture to give a visual of what it currently looks like. Attachment 12268
in the basement as u will create a negative pressure in the area of the water heater & furnace and pull products of combustion into the base and distribute them through the house , really a non no!!!!!!!......Jack
psilliman001 is offline   Reply With Quote
frost clogging furnace air intake geep HVAC 5 01-22-2009 05:32 PM
Furnace installed. Intake from outside. DO i need it? Northland101 HVAC 5 11-28-2008 03:03 PM
Air Intake vents....do I need them in basement? yummy mummy HVAC 7 09-21-2007 03:55 PM
Filter For Air Intake For Central Ac bobo General DIY Discussions 3 05-17-2005 04:52 PM
