Insurance Company Doesnt Like My Chimney... - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 02:03 PM   #1
Rewards Points: 107
Insurance company doesnt like my chimney...
I got a call from my insurance company today. Apparently they didnt know I had heat in my garage. I think they are going to want to inspect it. I know it is not up to code. It is a Lennox oil burner. There is no attic space so the chimney goes right out the roof. Is it to code to run single wall pipe and only run double wall insulated two feet under and above the roof? If so, is there an adapter to hook the single to double. Thanks
thunderhead is offline   Reply With Quote
Old 05-05-2009, 02:38 PM   #2
What is not up to code?
The pipe?
Generally single pipe goes to a thimble/adaptor in the ceiling before the roof
After that double wall goes thru the roof & "x" distance over the peak/nearest roof
My last house the single/double transition took place at the sheetrock in the ceiling
Old 05-06-2009, 01:18 AM   #3
Rewards Points: 107
It may have been to code 25 years ago when I installed it. It is a 6" pipe with a 8" pipe around it, with screws keeping the 2 separated. Thanks for the help.
Garage value estimate - Insurance company run-around twd General DIY Discussions 10 03-18-2009 09:23 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
What kind of roof is this? cwelte Roofing/Siding 16 02-23-2008 01:17 AM
