Insulation On Tube Ducts In Attic Splitting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 05:06 PM   #1
Insulation on tube ducts in attic splitting
I have a question, should I attempt a repair for this problem, or is this system so outdated that I should replace all of the ducting in the attic?
Thanks!!
dkinchi is offline   Reply With Quote
Old 02-27-2011, 10:19 PM   #2
If it's all the same age duct, you need to replace it all...not a hard job, just long and dirty. Be sure to air seal all duct connections.
Poppyloppy is offline   Reply With Quote
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 01:46 PM
Attic insulation Hammiamm Roofing/Siding 5 12-02-2008 03:39 PM
