Insulation Tape - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 12:52 AM   #16
Registered User
Rewards Points: 4,910
Sounds like the air supply to each should be separate. If in same room, they may need an outside air source. Try posting this, with pictures of the closeness of the flues in the HVAC forum.
"oh, and asfor the unfinished ceiling, that shouldnt matter because sheetrock is a rating of 50 perm, right?" ---- yes, for permeability rating. It doesn't really have to do with lack of air to the appliances, does it? Sorry I can't help you more, John.
Be safe, Gary
Old 12-05-2009, 09:17 AM   #17
so you dont think it has anything to do with my sealing insulation upstairs? to be honest with you i really dont feal lioke taping al the seems! because technicly if i seal off my mechanical room the down draft prob should go away. i just thaught this was the wrong solution. to be honest with you i dont really know the "brearhability" of a house is supposed to work. thanks for the input.
also is there anyway i can transfer my last post to hvac withouthaving to retype it all, thats a lot of typing for me!
roadhouse is offline   Reply With Quote
Old 12-05-2009, 02:54 PM   #18
Registered User
I tried to inform them..... but I don't know exactly how.
MODERATORS........................................ ... read previous post.
Here is my County's HVAC on ducts, air supply and such: http://www.mybuildingpermit.com/Insp...0checklist.pdf To give you an idea.
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Heat tape WITH insulation justinae Plumbing 2 03-25-2009 11:50 AM
butting insulation between studs-need to tape? yummy mummy Building & Construction 2 02-09-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
