Insulation Missing From Condensor Pipes - Big Deal? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 08:49 AM   #1
Rewards Points: 590
Insulation missing from condensor pipes - Big deal?
What kind of efficiency is being lost by this partially insulated pipe? Why is one insulated and the other is not? Thanks.
noone is offline   Reply With Quote
Old 06-29-2011, 10:09 AM   #2
Not much different for that small section. but it is good to insulate it again. The small copper line is about room temp, there is no need to insulate the small line. but the big line is very cold, needs to be insulated.
clocert is offline   Reply With Quote
The Following User Says Thank You to clocert For This Useful Post:
noone (06-29-2011)
Old 06-29-2011, 10:10 AM   #3
Rewards Points: 6,652
On a Heat pump, that larger pipe carries the heated or cooled refrigerant, depending on if wanting to heat or cool the home. On a A/c, it is only cooled refrigerant, because there is no reversing valve on a A/c.
The Following User Says Thank You to gregzoll For This Useful Post:
noone (06-29-2011)
Old 06-29-2011, 05:16 PM   #4
An old Tradesmen
Rewards Points: 7,278
Only losing a hundred to 200 BTUs from that uninsulated section, in cooling mode.
Old 06-29-2011, 05:18 PM   #5
Rewards Points: 590
That sounds like a lot.
Old 06-29-2011, 05:24 PM   #6
Connections look like they go to a Lennox ,about a 4 ton. That's roughly 48,000 BTU so 100-200 loss is next to nothing.
Old 06-29-2011, 05:27 PM   #7
Rewards Points: 590
Wow. You guessed it right. Lennox. Not sure of the tonnage though. Nice.
Old 06-29-2011, 05:37 PM   #8
An old Tradesmen
A 1.5 ton unit is a nominal 18,000 BTUs. So at a 200 BTU loss, you would be losing .0111% of your total capacity.
Also, that 200 BTU loss, would be on the hottest of the hottest days.
Old 06-29-2011, 06:07 PM   #9
You can actually go to the local hardware store, and get the insulation that is for 3/4 piping to put over that section. Just cut away the bad, and place the new piece. Just secure with either Zip ties, or a couple of wraps of Electrical tape to hold the new piece securely.
The "biggest loser" in fiberglass insulation.... Gary in WA How To Guides 2 01-20-2015 06:19 PM
Loose fill asbestos insulation, Vermiculite GeauxCajuns82 Building & Construction 2 03-07-2011 05:59 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
