Insulating A Range Hood? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 07:34 PM   #1
Insulating a range hood?
I have a range hood that vents through a wall into my garage that is not insulated. This was installed this past Feb. My old range hood was a recirculating type. Although it has a damper which opens/closes automatically when it's on/off, I feel a draft through the range hood. I'm thinking this could have raised my heating/electric bill by 500 kW/h. I nearly messed my pants when I saw the bill!
Is there anyway that I could insulate the damper, or the ducting?
If not possible, what are my alternatives?
snapshotmd is offline   Reply With Quote
Old 01-13-2009, 08:02 PM   #2
An old Tradesmen
Rewards Points: 7,378
No good way.
But, its showing you, that your house has a lot of air leakage.
Seal the switches and receps on outside walls.
Seal/replace worn door seals.
Caulk around your windows.
Old 01-13-2009, 08:24 PM   #3
BT knows way more about drafts than I, but I have found a horizontal steel vent with weighted damper and felt seal that has made a HUGE difference for both my dryer and range hood. I would add that to his list.
Chemist1961 is offline   Reply With Quote
Old 01-13-2009, 08:55 PM   #4
An old Tradesmen
Be carefull of felt deals in range hood vents.
They can trap grease.
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 10:35 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
