Insulating A Radiant Heated Floor (below Slab) -- Use Foam Board? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 08:52 AM   #1
drh
Insulating a radiant heated floor (below slab) -- use foam board?
Quick question to all the radiant floor (basement concrete) experts out there.
I'm in the process of having our basement floor broken up, dropped down a foot and re-poured with a PEX in-floor heating system installed (in-floor).
Concerning the insulation *beneath* the PEX, our contractor has quoted us to use a "Reflector Pad" beneath the PEX. I'm concerned this may not be enough and am considering laying down 1" or 2" high-density rigid foam board over top of the gravel BENEATH the concrete altogether.
Can someone illustrate whether my approach is overkill? Would adding a rigid foam barrier between the gravel and concrete be necessary if a reflector pad is already in the plan to be installed beneath the PEX?
I've got one shot at having the floor built properly, and I want to be certain we're doing it right the first time.
Many thanks,
Dan
drh is offline   Reply With Quote
Old 01-14-2008, 09:13 AM   #2
Rewards Points: 1,274
Go with the foam.
LawnGuyLandSparky is offline   Reply With Quote
Old 01-14-2008, 03:42 PM   #3
Union HVAC Tech.
Go with the foam but, make sure the gravel is compacted flat so you don't develope stress cracks in the new floor if it's supported unevenly.
bigMikeB is offline   Reply With Quote
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 12:59 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 11:59 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
