Insulating For Radiant Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 09:42 PM   #1
Insulating for radiant heat
I'm building a new 1500 sq feet house in the spring and have a question about insulation. I will have in-floor heat in the basement the garage and on the main floor. In the garage I know I need to insulate under the slab. In the basement since the slab is 8ft under ground do I still need to insulate under the slab. What about the main floor since there will be the warm basement underneath do I still need to insulate. If so what is the method to insulate the main floor. Do I insulate between the joist or over the plywood before the concrete gets poured. Thanks in advance.
mugen is offline   Reply With Quote
Old 02-21-2010, 10:12 PM   #2
An old Tradesmen
Rewards Points: 6,576
You MUST insulate the basement floor if you want it to work. And not cost more to heat then a 5,000 sq ft house.
What type of flooring will you have on the first floor.
Old 02-21-2010, 10:17 PM   #3
Ceramic tiles
Old 02-22-2010, 12:49 PM   #4
Rewards Points: 1,910
If you are putting the tubes in gypcrete or light weight concrete on the main floor (over a wood subfloor) I believe the usual practice is to insulate from underneath between the joists.
Old 02-22-2010, 03:40 PM   #5
An old Tradesmen
Yes, that is the easiest way, and doesn't lose you height in your home.
Old 02-22-2010, 03:57 PM   #6
Home Air Direct's Avatar
INSULATE!! INSULATE!! INSULATE!!
And if I forgot to mention it......INSULATE
Under the concrete (Basement and Garage) WBBF (White-Bubble-Bubble-Foil) or 1 1/2" foil faced BlueBoard (like you can buy at the home center).
As to the rest of the house, you will want to insulate up in the joist spaces with the foil facing up toward the tubing.
Oh yeah, one more thing......INSULATE!!!
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 02-22-2010, 04:36 PM   #7
Are you talking about this stuff:
http://www.buyfoilinsulation.com/All...ble-Insulation
In my detached garage I built a few years ago I used that 1 1/2" blue rigid foam insulation. I the WBBF as good or better than the foam.
Old 02-22-2010, 04:48 PM   #8
ICF built home
Yes, you should insulate under the concrete slab in the basement.
However, foil faced products are of very limited benefit under a concrete slab. The reflective foil when used properly is for reflecting "radiant" energy not "conductive" energy. But when the foil is sitting under a concrete slab the reflective properties of the foil are useless. In this situation the insulation is operating in a "conductive" environment. The best for this situation is rigid foam (blue or Pink).
Foil products require an air gap to function properly. This is what you would typically find between floor joists. The foil then has the ability to work as designed, reflecting. If used under a slab the only thing providing insulation are the bubbles themselves. About a R-1.
Google search a variety of things starting with Slab Insulation and foil insulation under concrete slab.
Here is just one result: http://www.naturalspacesdomes.com/be...st_results.htm
After reading several sites you will quickly determine that rigid foam is best. Don't believe the sales pitch hype on those foil bubble wrap insulation for underslab insulation. Read the details from many sites and you should start getting a consistent picture.
Here is a quote from Wikipedia:
"The effectiveness of aluminum foil or metallised film radiant barrier in preventing heat loss is negated if it abuts any material with high thermal conductivity. Reflective foil needs an air gap to function as a conduction insulation material. A radiant barrier system is defined as a reflective material facing an air space. When the radiant barrier faces an enclosed air space it becomes a reflective insulation with a measurable R-value."
Quote from above is from here:
http://en.wikipedia.org/wiki/Thermal_insulation
Here is another: http://www.rimainternational.org/myths/index.html
Those Foil faced Bubble wrap insulation products have their place; it is just not as an insulation under a concrete slab.
Generally 2 inches of rigid foam seems to be a good compromise between cost and performance. This is especially critical in cold weather climates.
Dragon is offline   Reply With Quote
Old 02-22-2010, 04:56 PM   #9
An old Tradesmen
For slabs. The more insulation you put down, the better.
Old 02-22-2010, 11:01 PM   #10
So would I use the WBBF for the main floor. Or should I use foam insulation since I will be doing all my walls with it.
Old 02-22-2010, 11:06 PM   #11
An old Tradesmen
Since your heating the basement. You don't need to use spray foam for the floors.
Unless your not going to heat the basement 24/7.
Have you ran your ducts for your ERV/HRV since your foaming.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
